Add new PushButton when I click pushbutton
qoreodlf37
qoreodlf37
Hi, I have a question.
I created tab, pannel and some buttons.
Is it possible to create new pushbutton (Button3, Button4...) when I click  my "Create" button?
jeremy_tammik
Yes, almost certainly. You just need access to the RibbonPanel object, create new PushButtonData objects, and call AddPushButton. Why would you want to do this? Is your goal to confuse your end user? Another possible approach would be to create all required buttons up front and only enable them when they are needed.
Mohamed_Arshad
Hi @qoreodlf37
    There is no direct method to achieve that functionality, But we have a workaround to achieve that.
1. Create all Button in the IExtetnal Application
2. Add "AdWindows" Dll and Hide Button2 and Button3
3. In Create Command UnHide the Button2 and Button3
Reference Video
Reference Code (IExternalApplication)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Reflection;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.UI;
using WD = Autodesk.Windows;
namespace PushButtonCreation
    public class App : IExternalApplication
        #region Global Variables
        private static readonly string TabName = "Demo";
        private static readonly string PanelName = "My Ribbon Panel";
        #endregion
        public Result OnShutdown(UIControlledApplication application) => Result.Succeeded;
        public Result OnStartup(UIControlledApplication application)
            string dllLoc = Assembly.GetExecutingAssembly().Location;
            ///Create Tab
            application.CreateRibbonTab(TabName);
            ///Create Panel
            RibbonPanel panel = application.CreateRibbonPanel(TabName, PanelName);
            /// Create PushButtonData
            PushButtonData createButtonData = new PushButtonData(
                "createBtn",
                "Create",
                dllLoc,
                "PushButtonCreation.CreateCmd");
            PushButton pushButton = panel.AddItem(createButtonData) as PushButton;
            PushButtonData button_2_Data = new PushButtonData(
               "Btn_2",
               "Button_2",
               dllLoc,
               "PushButtonCreation.Button_2");
            PushButton pushButton_2 = panel.AddItem(button_2_Data) as PushButton;
            PushButtonData button_3_Data = new PushButtonData(
               "Btn_3",
               "Button_3",
               dllLoc,
               "PushButtonCreation.Button_3");
            PushButton pushButton_3 = panel.AddItem(button_3_Data) as PushButton;
            HideButtons();
            return Result.Succeeded;
        public void HideButtons()
            foreach (WD.RibbonTab tab in WD.ComponentManager.Ribbon.Tabs)
                if (tab.Name == TabName)
                    foreach (WD.RibbonPanel panel in tab.Panels)
                        if (panel.Source.Name == PanelName)
                            foreach (WD.RibbonItem item in panel.Source.Items)
                                if (item.Text == "Button_2" || item.Text == "Button_3")
                                    item.IsVisible = false;
Create Command (IExternalCommand)
using System;
using System.Linq;
using System.Text;
using Autodesk.Revit.Attributes;
using Autodesk.Windows;
    [Transaction(TransactionMode.Manual)]
    public class CreateCmd : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            ShowButtons();
        public void ShowButtons()
            foreach (RibbonTab tab in WD.ComponentManager.Ribbon.Tabs)
                if (tab.Name == "Demo")
                        if (panel.Source.Name == "My Ribbon Panel")
                                    item.IsVisible = true;
Kindly check the attached project for additional reference.
Mohamed Arshad K
Software Developer (CAD & BIM)
