Add-In-Manager Dialog Box Does Not Show Up
I am following a tutorial to learn Revit API. In order to follow along with the tutorial, I need to use Add-In-Manager. Unfortunately the Add-In-Manager dialog box (to show a list of add-in DLLs) does NOT show up.
After I have installed the Add-In-Manager and launch Revit, Revit prompts me to confirm that I want to load the AddInManager.DLL file, and I choose "Always Load". And I can see the three Add-In-Manager commands available under "External Tools" pull down menu. But when I try any one of the Add-In-Manager command, I see nothing. There is no dialog box, no error message, no beep.
Yes, I have updated the .addin file to replace [TARGETDIR] with the correct folder location. I am sure this has nothing to do with the problem. Otherwise, Revit would not have prompted me to confirm loading the DLL from that folder.
I have tried saving the AddInManager.DLL and its .addin file to either %appdata% folder or %programdata% folder. But this doesn't make any difference.
I have tried leaving the AddInManager.DLL in the same folder as its .addin file (of course I have updated the .addin file accordingly). But this doesn't make any difference either.
Meanwhile, the similarly installed Revit-Lookup add-in works fine.
The problem is that I don't see any error message because Revit doesn't have a Command Prompt to show any message. I have checked Event Viewer in Windows; but I don't see anything related to Add-In-Manager.
I have also checked the version of Add-In-Manage (in its AddInManager.dll.config file), and it matches the version of Revit that I use (2021).
My questions are:
1. Any suggestion to fix this problem?
2. Is there a place where Revit stores all the hidden error messages? I wonder if Add-In-Manager has sent an error message to Standard-I/O and got captured and stayed hidden.
3. Can I run my add-in (an External Command) without using Add-In-Manager? Then I can move along with the tutorial.
Please help. Thanks!
JC_BL
