Add addin to existing ribbon
I created an addin that has a tab with a few buttons on it but not enough to fill up the full tab. What i would like to take the panels that have created and  see if it is possible to add it to a tab  that already exists like "CTC Tools" just to simplify access locations for the users in the office. Is it possible to add on to a tab without creating it first? I know that if I don't create a tab the panel will be placed on the Add-ins Tab but for some users that is filled up. And I also know that if I try creating 2 panels with the same name that only the first one it loads will show up.
public Result OnStartup(UIControlledApplication application)
AddDfltWkstRibbon(application);
public void AddDfltWkstRibbon(UIControlledApplication application) { // create ribbon tab //String TabName = "General"; //application.CreateRibbonTab(TabName); String PanelName = "Worksets"; RibbonPanel PanelRibbon = application.CreateRibbonPanel(PanelName); string msg = "Sets the workset and also sets a user prefered workset."; PushButtonData wkst = new PushButtonData("DfltWorkset", "Default" + Environment.NewLine + "Workset", ExecutingAssemblyPath, ExecutingAssemblyName + ".CmdSetWorkset") { ToolTip = msg }; PushButton pb = PanelRibbon.AddItem(wkst) as PushButton; }
Thanks in Advance
jeremytammik
Dear William,
Thank you for your query.
Yes, this can be done:
http://thebuildingcoder.typepad.com/blog/2013/02/adding-a-button-to-existing-ribbon-panel.html
Please always search the Internet and the blog before asking a question.
That said, please be very careful using this.
Note that this approach is not officially supported by the Revit6 API:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#4
I heard rumours that adding custom add-in buttons to existing built-in Revit ribbon panels may have caused serious crashes in the past.
As always, test carefully and thoroughly before letting this loose on unsuspecting customers.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
