Add a calculated field to a schedule via the API
MattKincaid
MattKincaid
Hi
I'm writing an addin to create schedules.  I have two fields in my schedule, let's call them "parameter a" and "parameter b".  I want to add a third field that is {parameter a} divided by {parameter b}.  Is this possible to do in the api?
Thanks.
Dear Matt,
As i research and find. you could not add calculated field using API for schedule. you can add only available parameter according to schedule definition. For more information you can visit
http://forums.autodesk.com/t5/revit-api/schedule-calculated-value-field/m-p/3786727#M3666
thanks.
