Adaptive Families / element geometry and intersection
Hi folks,
I’m creating a bridge with Revit 2017 2.2. I use nested adaptive families for the bridge design. I put cross sections along a grade and sweep them.
But when I create sections, it is not possible to measure them.
So I thought I can create a flat disc through the bridge and use the geometry that intersects to draw modellines in the section view to measure.
3D-View
Section View
But as you see, the adaptive familie doesn’t intersect! Only the “normal” generic model families create intersections with the disc.
I figured out, that there is no element geometry behind my adaptive family. The generic model families with sweeps inside have element geometries.
Warning: Element.Geometry failed. Value can not be null.
So is there a possibility to intersect with adaptive families? Is there an other way to get measurable section views or what am I doing wrong?
FAIR59
Adaptive Families are shared. The geometry of shared nested families doesn't "transfer" to the bridge family.
So you have to find the nested families to get their geometry.
FamilyInstance instance; // bridge
List<ElementId> nestedFamilyIds =  instance.GetSubComponentIds().ToList();
Thanks, that helps a lot!
Hm,
I tried
for subcomp in item.GetSubComponentIds():
		itemlist.append(item.Document.GetElement(subcomp).ToDSType(True))
But then I only get the other adaptive families inside the element and not the 3-D solid body I created. Is there a way to get the 3-D solid body also?
FAIR59
In general, I would say the geometry should be available. In your specific case, I can't comment without access to your project and family.
there were 3 solid bodies in one family. This was probably the problem. I decided to create every solid in an extra family and know the geometry is available.
Thanks for your help.
