Accessing BuiltInParameter.RBS_PIPE_FLUID_TEMPERATURE_PARAM in Revit 2018 fails
xavier.atero
Message 1 of 1
xavier.atero
I am trying to read the fluid temperature of a system using the following code:
// read MEPSystem in system variable
// ... if (system is PipingSystem) { PipingSystem piping_system = system as PipingSystem; PipeSystemType system_type = piping_system.SystemType; if (system_type == PipeSystemType.DomesticColdWater || system_type == PipeSystemType.DomesticHotWater || system_type == PipeSystemType.ReturnHydronic) { Parameter parameter__temperature_of_fluid = piping_system.get_Parameter(BuiltInParameter.RBS_PIPE_FLUID_TEMPERATURE_PARAM); } }
Exceuting the code on Revit 2017:
  • parameter__temperature_of_fluid = {Autodesk.Revit.DB.Parameter}
Exceuting the code on Revit 2018:
  • parameter__temperature_of_fluid = null
I have tried with both 2017 and 2018 dlls and the result is the same; the OS is Windows 10. Any ideas? Thanks in advance.
Replies (0)
