Access Wall Faces
Access Wall Faces
caltineller
Access Wall Faces
caltineller
I am pretty new to API. Basically I find other codes and try to modify them to my needs:) What I try to do is to access wall core faces, namely core face interior and core face exterior.
HostObjectUtils.GetSideFaces(element, ShellLayerType.Exterior) This is only accessing the very outside face of the wall. How do I access the core layers?
Dear,
You mean structure of wall ? Please see image....
to find this you can use
CompoundStructure cs = (el as WallType).GetCompoundStructure();
if (cs != null && cs.GetLayers().Count > count)
foreach (CompoundStructureLayer csl incs.GetLayers())
caltineller
Yes, but this is not I want. I'm trying to give dimensions to Core Boundarys. From Core to Core. Counting will not work for me, because I have many types of walls in my project. So I need a direct access to this Core definition.
In the example picture you can see how I want my dimension to look.
matthew_taylor
Take a look at the notes on the CompoundStructure class. It looks like you can get the core details.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Annonymous24
have you found any solution for this?
