Access/Retrieve Document of picked linked element in revit link instance.
mr.engineer.aec
mr.engineer.aec
 Hi All,
I'm in host model and i selected beam in linked file.
I want to retrieve linked document of beam (to get location line). But wrong !
How can i solved this problem ?
Thank in advanced !
Reference pickObject = uidoc.Selection.PickObject(ObjectType.LinkedElement, "Pick element in linked file.");
//doc = document in host file.
beam = doc.GetElement(pickObject) as FamilyInstance;
//Location
Line beamLine = ((beam.Location as LocationCurve).Curve as Line);
joshua.lumley
I think this will work:
LinkElementId myLinkElementId = pickObject.LinkedElementId as LinkElementId;
RevitLinkInstance linkedDoc = doc.GetElement(myLinkElementId.LinkInstanceId) as RevitLinkInstance;
mr.engineer.aec
 Thank for your relpy. I'll trying
AmitMetz
pickedObject.ElementId return the RevitLinkInstance Id (What we need)
pickedObject.LinkedElementId return the Element Id
//Get UIDocument and Document
UIDocument uidoc = ActiveUIDocument;
Document doc = uidoc.Document;
//Define Link Document
Document linkDoc = null;
//Select element in link
Reference pickObject = uidoc.Selection.PickObject(ObjectType.LinkedElement,"Pick element in link");
if (pickObject != null)
	RevitLinkInstance link = doc.GetElement(pickObject.ElementId) as RevitLinkInstance;
	linkDoc = link.GetLinkDocument();
jvideiraGZHPC
why those suggestions don't work if the Reference is a PlanarFace and not an object picked by the user?
How can I make it work
davidarh
Hi, I just had a similar problem and ended up combining code from different places. Please see the Macro below that goes though the whole process of selecting an object of a specific type, getting the linked document and getting the element in the linked document as well.
Hope this helps someone!
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace PickLinkedElement
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("5EC5C348-E15F-478E-9E88-6876CBE9D21F")]
	public partial class ThisDocument
		private void Module_Startup(object sender, EventArgs e)
		private void Module_Shutdown(object sender, EventArgs e)
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
		public void SelectWindow()
			var uiDoc = this.Application.ActiveUIDocument;
			var doc = this.Document;
		    Document linkedDoc = null;
		    Reference pickedObject = uiDoc.Selection.PickObject(ObjectType.LinkedElement, new GroupPickFilterWindow(),  "Please pick a window in the linked model");
		    //Add code to get linked document here.
		    if (pickedObject != null)
				var linkedEleemnt = doc.GetElement(pickedObject.ElementId) as RevitLinkInstance;
				linkedDoc = linkedEleemnt.GetLinkDocument();
				var linkElement = linkedDoc.GetElement( pickedObject.LinkedElementId);
				TaskDialog.Show("element", linkElement.Name + "  - " + linkElement.GetType().ToString() + " - " + linkedDoc.PathName);
	// This filter allows selection of only a certain category in a link instance.
	public class GroupPickFilterWindow : ISelectionFilter
	    private RevitLinkInstance m_currentInstance = null;
	    public bool AllowElement(Element e)
	        // Accept any link instance, and save the handle for use in AllowReference()
	        m_currentInstance = e as RevitLinkInstance;
	        return (m_currentInstance != null);
	    public bool AllowReference(Reference refer, XYZ point)
	        if (m_currentInstance == null)
	            return false;
	        // Get the handle to the element in the link
	        Document linkedDoc = m_currentInstance.GetLinkDocument();
	        Element e = linkedDoc.GetElement(refer.LinkedElementId);
	        // Accept the selection if the element exists and is of the correct type
	        if (e.Category != null && e.Category.Id.IntegerValue.Equals((int)BuiltInCategory.OST_Windows))
	            return true;
	        else
	            return false;
