Access ifc options of AutodeskIFCForRevit2016.msi
hi all,
I have installed the plug'in "AutodeskIFCForRevit2016.msi"
I would like to have access by vb.net to the list of options, in order to be able to modify them, before doing the export IFC
If someone can tell me how I should do to access the ifc options
Thank you very much
Alex
jeremytammik
Dear Alex,
Afaik, this module is provided by the open source community around the IFC import and export functionality:
https://sourceforge.net/projects/ifcexporter/
You will probably have better luck getting an answer to your question on the corresponding discussion forum there:
https://sourceforge.net/p/ifcexporter/discussion/
Furthermore, as the whole project is open source, you have full access to the source code and can modify that as you see fit to manipulate those options any way you like.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
