accesing project parameters
hi all
i am trying to create a new project parameter and bind oit to a shared parameter
i read the api document of autodesk used the code examples
and came up with this
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
<Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)> _
<Autodesk.Revit.VSTA.AddInId("056e4a87-ca78-4e44-8540-dda2100c7547")> _
Partial Public Class ThisDocument
    Private Sub Module_Startup(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Startup
    End Sub
    Private Sub Module_Shutdown(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Shutdown
    End Sub
    Public Sub a()
        Dim uiApp As UIApplication = Me.Application
        Dim doc As Document = uiApp.ActiveUIDocument.Document
        'Dim projinfo As Autodesk.Revit.DB.Category = doc.Settings.Categories.Item(BuiltInCategory.OST_ProjectInformation)
        ' Dim cats1 As CategorySet = uiApp.Application.Create.NewCategorySet()
        'cats1.Insert(projinfo)
        'RawCreateProjectParameterFromExistingSharedParameter(uiApp, "ExistingParameter1", cats1, BuiltInParameterGroup.PG_DATA, False)
        'RawCreateProjectParameterFromNewSharedParameter(uiApp, "NewDefinitionGroup1", "NewParameter1", ParameterType.Text, True, cats1, BuiltInParameterGroup.PG_DATA, False)
        'RawCreateProjectParameter(uiApp, "TemporarySharedParameter", ParameterType.Text, True, cats1, BuiltInParameterGroup.PG_DATA, True)
        Dim deffile As DefinitionFile
        Dim fname As String
        fname = "I:\down\onderhoek\1.txt"
        Dim projinfo As ProjectInfo = doc.ProjectInformation
        uiApp.Application.SharedParametersFilename = fname
        DefFile = uiApp.Application.OpenSharedParameterFile
        If defFile Is Nothing Then
            Throw New Exception("No SharedParameter File!")
        Dim myGroups As DefinitionGroups = deffile.Groups
        Dim myGroup As DefinitionGroup
        Dim myDef As Definition
        If myGroups.Item("MyParameters2") Is Nothing Then
            myGroup = myGroups.Create("MyParameters2")
        Else
            myGroup = myGroups.Item("MyParameters2")
        If myGroup.Definitions.Item("Instance_ProductDate") Is Nothing Then
            myDef = myGroup.Definitions.Create("Instance_ProductDate", ParameterType.Text)
        Else
            myDef = myGroup.Definitions.Item("Instance_ProductDate")
        Dim myCats As CategorySet = uiApp.Application.Create.NewCategorySet
        Dim myCat As Category = uiApp.ActiveUIDocument.Document.Settings.Categories.Item(BuiltInCategory.OST_ProjectInformation)
        myCats.Insert(myCat)
        Dim instanceBinding As InstanceBinding = uiApp.Application.Create.NewInstanceBinding(myCats)
        MsgBox("7")
        Dim bindingMap As BindingMap = doc.ParameterBindings
        MsgBox("8")
        bindingMap.Insert(myDef, instanceBinding, BuiltInParameterGroup.PG_TEXT)
    End Sub
End Class
this only works when i have already a project parameter "ExistingParameter1 defined in my project parameters
is it possible to create my own project parameter an attach the shared parameter to the project parameter ??????
hi all
solved it forgot new statement and transaction
Public Sub a()
Dim fname As String
Dim Transaction As Transaction = New Transaction(doc)
If (Transaction.Start("parameter") = TransactionStatus.Started) Then
Dim myDef As ExternalDefinition
Else
MsgBox("3")
Else
Dim bindingMap As BindingMap = (New UIApplication(uiApp.Application)).ActiveUIDocument.Document.ParameterBindings
Transaction.Commit()
End Sub
mertens3d
jetfreggel01,
Did you come across a way to set the value of a Project Parameter?
If so, can you share that info?
...gregory
Joe.Ye
Setting value for the project parameter can be done in the same way as setting normal parameter value..
Retrieve the Parameter variable, and then set value via Parameter.Set() method.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
mfleming.stantec
Anyone have this full working example in C# by chance?
