A simple question re Modellines
dsmith
dsmith
Hi
m trying to modify the start and end of a Modelline I created, but I cannot find out how this can be done. I know I can recreate it but I need to maintain the ID as it is uses elswhere
Any pointer would be great
Thank you in Advance
smarente1
The endpoint property only has a get method:
https://www.revitapidocs.com/2022/fa84492f-aaea-004c-2443-d02b6ca83c1d.htm
And the length is read only and cannot be set.
Looks like you can only recreate the model line and store the old element Id in an associative array.
mhannonQ65N2
Try using the SetGeometryCurve method. Also, a LineSegment is not a model line.
