A question about suppressing warning messages in Revit
Message 1 of 13
Hi Everyone:
    I am a  newcomer to develop RevitAPInow I have a question about suppressing  warning messages.
when we use  "Paste/ AlignedToSelectedLevels"command to paste elements, if some of these are overlap, Revit displays the following warning message:
Now I creat a addin, in which I use “uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.AlignedToSelectedLevels));” to paste some elements ,meanwhile I want to suppressing this warning messages and get these messages .
This is my code:-
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Events;
using System.Threading;
namespace DeleteWarningElement
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    [Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)]
    public class Class1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document doc = uidoc.Document;
            Transaction transaction = new Transaction(doc, "BIM");
            FailureHandlingOptions options = transaction.GetFailureHandlingOptions();
            options.SetFailuresPreprocessor(new FailurePreproccessor());
            transaction.SetFailureHandlingOptions(options);
            transaction.Start();
            TaskDialog.Show("1", "12");
            Thread.Sleep(5000);
            transaction.Commit();
            return Result.Succeeded;
    public class FailurePreproccessor : IFailuresPreprocessor
        public FailureProcessingResult PreprocessFailures(FailuresAccessor failuresAccessor)
            IList<FailureMessageAccessor> failList = failuresAccessor.GetFailureMessages();
            if (failList.Count == 0)
                TaskDialog.Show("1", failList.Count().ToString());
                return FailureProcessingResult.Continue;
            foreach (FailureMessageAccessor failure in failList)
                TaskDialog.Show("1", "123");
                FailureDefinitionId failID = failure.GetFailureDefinitionId();
                if (BuiltInFailures.CopyPasteFailures.CannotDuplicateWarn==failID)
                    failuresAccessor.DeleteWarning(failure);
            return FailureProcessingResult.ProceedWithCommit;
When I  executed the code, I found this warning was not suppressed. I also found that“  Transaction transaction = new Transaction(doc, "BIM");  is  a null operation, so what is Transaction of PostCommand in Revit .
how to solve this problem?
Looking forward to your reply!
GoodLuck!
Replies (12)
Message 2 of 13
Mustafa.Salaheldin
Try this and tell me if it works like a charm
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                UIApplication uiapp = cmdData.Application;
                uiapp.Application.FailuresProcessing += FaliureProcessor;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        private void FaliureProcessor(object sender, FailuresProcessingEventArgs e)
            FailuresAccessor fas = e.GetFailuresAccessor();
            List<FailureMessageAccessor> fma = fas.GetFailureMessages().ToList();
            foreach (FailureMessageAccessor fa in fma)
                if (fa.GetFailureDefinitionId() == BuiltInFailures.OverlapFailures.DuplicateInstances)
                    fas.DeleteWarning(fa);
        #endregion
If this satisfies your need please don't forget to mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 3 of 13
Thanks Mustafa.Salaheldin.
Your codes sloved how to suppress warning messages. this is what I need.
In your codes,you use event--" uiapp.Application.FailuresProcessing += FaliureProcessor;" ,but you can not cancle this event after this command --"uiapp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.AlignedToSelectedLevels)); "is excuted,so how to cancle it?
And ,in my add-in,I want to not only implement function dismissing warning messages, but also implement function deleting ElementId contained in this warning messages.
How should I do?
Message 4 of 13
BobbyC.Jones
That's a couple of really great questions, and detecting when a PostableCommand has ended is a problem I've been looking at.  Here's my first stab at it.  Fair warning, I've only tested this with a very small subset of PostableCommands, and not with the AlignedToSelectedLevels at all.  I'm very interested in how it works for you and any feedback the community may have.
Using Mustafa's excellent example in conjuction with the PostableCommandBase, here's what you're command class would look like.
using System;
using System.Linq;
namespace DWH.Core.Revit.Commands
    public class PostableCommandEndedExample : PostableCommandBase
        protected override PostableCommand PostableCommand => PostableCommand.AlignedToSelectedLevels;
        protected override RevitCommandResult Initialize(ExternalCommandData commandData, ElementSet elements)
            _cachedCmdData = commandData;
            commandData.Application.Application.FailuresProcessing += FaliureProcessor;
            return RevitCommandResult.Succeeded();
        protected override void OnCommandEnded(object sender, EventArgs eventArgs)
            _cachedCmdData.Application.Application.FailuresProcessing -= FaliureProcessor;
            var failureAccessor = e.GetFailuresAccessor();
            var duplicateInstancesMessages = failureAccessor.GetFailureMessages().
                Where(messageAccessor => messageAccessor.GetFailureDefinitionId() == BuiltInFailures.OverlapFailures.DuplicateInstances);
            foreach (var message in duplicateInstancesMessages)
                failureAccessor.DeleteWarning(message);
using System;
    public abstract class PostableCommandBase : IExternalCommand
        protected abstract PostableCommand PostableCommand { get; }
        public Result Execute(ExternalCommandData commandData, ref string failureMessage, ElementSet elements)
            var initResult = Initialize(commandData, elements);
            if (initResult.CommandResult != Result.Succeeded)
                failureMessage = initResult.FailureMessage;
                return initResult.CommandResult;
            PostCommand(commandData.Application);
        private void PostCommand(UIApplication revitUiApplication)
            var commandMonitor = new RevitCommandEndedMonitor(revitUiApplication);
            commandMonitor.CommandEnded += OnCommandEnded;
            revitUiApplication.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand));
        protected abstract RevitCommandResult Initialize(ExternalCommandData commandData, ElementSet elements);
        protected virtual void OnCommandEnded(object sender, EventArgs eventArgs)
using System;
    public class RevitCommandEndedMonitor
        private readonly UIApplication _revitUiApplication;
        private bool _initializingCommandMonitor;
        public event EventHandler CommandEnded;
        public RevitCommandEndedMonitor(UIApplication revituiApplication)
            _revitUiApplication = revituiApplication;
            _initializingCommandMonitor = true;
            _revitUiApplication.Idling += OnRevitUiApplicationIdling;
        private void OnRevitUiApplicationIdling(object sender, IdlingEventArgs idlingEventArgs)
            if (_initializingCommandMonitor)
                _initializingCommandMonitor = false;
                return;
            _revitUiApplication.Idling -= OnRevitUiApplicationIdling;
            OnCommandEnded();
        protected virtual void OnCommandEnded()
            CommandEnded?.Invoke(this, EventArgs.Empty);
    public class RevitCommandResult
        private RevitCommandResult(Result revitResult, string failureMessage ="")
            FailureMessage = failureMessage;
            CommandResult = revitResult;
        public string FailureMessage { get; private set; }
        public Result CommandResult { get; private set; }
        public static RevitCommandResult Failed(string failureMessage)
            return new RevitCommandResult(Result.Failed, failureMessage);
        public static RevitCommandResult Cancelled()
            return new RevitCommandResult(Result.Cancelled);
        public static RevitCommandResult Succeeded()
            return new RevitCommandResult(Result.Succeeded);
Bobby C. Jones
Message 5 of 13
Mustafa.Salaheldin
You can simply use
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
                CachedUiApp.Application.FailuresProcessing += FaliureProcessor;
                CachedUiApp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.AlignedToSelectedLevels));
                try
                        //use the following lines to delete the warning elements
                        List<ElementId> elemntsToDelete = fa.GetFailingElementIds().ToList();
                        fas.DeleteElements(elemntsToDelete);
                        //use the following line to disable the message supressor after the external command ends
                        CachedUiApp.Application.FailuresProcessing -= FaliureProcessor;
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 6 of 13
BobbyC.Jones
This will remove the custom failure processor, but from the current location will only remove it in the event of a failure of type DuplicateInstances; it will be active for all commands until then.
Does this display the elements to delete in the failure dialog tree as a potential failure resolution?  If so, that's much simpler than what I previously thought.
Bobby C. Jones
Message 7 of 13
Mustafa.Salaheldin
yes bobby this is needed to be done with the duplicate warning fired from the external command only. i.e. if you use the paste align command from the ribbon bar, it is so normal to see the warning again. That is required in our case.
For any other command we actually need to tweek the code to not suppres any related warnings by mistake as you refered.
For the second part of the code you can compare the ids of the elements returned with the ones appears in the warning dialog then clicking expand too see the full deltails.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 13
I used the following code to delete the warning elements:
but warning elements were not deleted;
I changed this code as follow:
IList<ElementId> elemntsToDelete1 = new List<ElementId>();
elemntsToDelete1.Add(elemntsToDelete[0]);
fas.DeleteElements(elemntsToDelete1);
This can detele some elements except pipes connected fitting(as shown in figure), when I paste pipes  connected fitting,there will be error:
What reason is this?Do you think how to deal with it?
Message 9 of 13
Mustafa.Salaheldin
Ok send the sample RVT file and what you want to do (i.e. which elements do you want to delete) then I may can help.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 10 of 13
I have two programs: testA and testB.
In my addin, I want to copy all elements included in testA and then paste (use this command: revitUiApplication.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand));) them on testB, if one warning message is pop-up ,I want to dismiss this warning message and delete elements in this warning message.
Could you please try it?
Message 11 of 13
Mustafa.Salaheldin
Here you are and don't forget to mark this as an answer if it satisfies your needs:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
            bool hasFailure = false;
                try
                        IList<ElementId> elemntToDelete = new List<ElementId>();
                        elemntToDelete.Add(elemntsToDelete[0]);
                        fas.DeleteElements(elemntToDelete);
                        hasFailure = true;
            if(hasFailure)
                e.SetProcessingResult(FailureProcessingResult.ProceedWithCommit);
            e.SetProcessingResult(FailureProcessingResult.Continue);
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 12 of 13
I used the above code,but there will be error:
                try
                        hasFailure = true;
                      TaskDialog.Show("`1", ex.ToString());
            if(hasFailure)
Message 13 of 13
Mustafa.Salaheldin
Here is the cure for all your pain. The error occured because you are trying to delete an element which is already deleted, so I filtered the elements to be deleted list from duplicated ids then celete the elements.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
            List<ElementId> ElemntsToDelete = new List<ElementId>();
                try
                        List<ElementId> FailingElementIds = fa.GetFailingElementIds().ToList();
                        ElementId FailingElementId = FailingElementIds[0];
                        if (!ElemntsToDelete.Contains(FailingElementId))
                            ElemntsToDelete.Add(FailingElementId);
                        hasFailure = true;
            fas.DeleteElements(ElemntsToDelete);
            if (hasFailure)
        #endregion
If this satisfies your needs don't forget to mark this reply as an answer.
¯\_(ツ)_/¯
Mustafa Salaheldin
