A question about "curve.evaluate()"
1393568367
1393568367
I want use this method to get XYZ on  such curve.    In my opinion the method  should have return (0,0,0)  ,  but now it return( 15.xxx, 17.xxx,0). i don't konw  why.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @1393568367 ,
How did you create the curve?
If you try to create a curve via UI then it might be inaccurate to select a point at (0,0,0).
please check whether the curve starting point is exactly (0,0,0).
also, check the below link to know more
curve-parameterisation
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
