3DView List in windows form combo box
Message 1 of 14
I want to create a combo box within a windows form that will show a list of all 3D views in the project (I am just testing combo boxes to use them in one of my add-ins).
When
When I run the external command the form shows up but the combo box is empty. I have searched a lot on this forum and other websites and cannot figure out what I am doing wrong.
This is the code of the external command:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace Drop_Down_List_Test
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class ViewList : IExternalCommand
        static AddInId appId = new AddInId(new Guid("536B73F0-36BF-4CBC-8CF9-EF0E7E210A90"));
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            using (ViewListForm thisForm = new ViewListForm())
                thisForm.ShowDialog();
                if (thisForm.DialogResult == System.Windows.Forms.DialogResult.Cancel)
                    return Result.Cancelled;
            return Result.Succeeded;
And this is the code of the windows form:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO;
    public partial class ViewListForm : System.Windows.Forms.Form
        public Document doc;
        public ViewListForm()
            InitializeComponent();
        private void ViewListForm_Load(object sender, EventArgs e)
            FilteredElementCollector fec = new FilteredElementCollector(doc).OfClass(typeof(View3D));
            foreach (Element elem in fec)
                View3D v = elem as View3D;
                if (!v.IsTemplate)
                    cbViewList.Items.Add(v.Name);
            cbViewList.DisplayMember = "ViewName";
        private void cbViewList_SelectedIndexChanged(object sender, EventArgs e)
Below screen grab of the 'empty' form after executing the command in Revit.
If you could help me that would be great.
Thanks.
Replies (13)
Message 2 of 14
Hi!
After your collector, try adding a List:
//for example
List<View3d> threeDlist = new List<View3d>();
foreach (View3d View3d in fec)
  threeDlist.Add(View3d);
return threeDlist;
Hope this helps!
Message 3 of 14
Revitalizer
in your ViewListForm class, doc variable isn't initialized.
You can add it as a parameter in the constructor:
public ViewListForm(Document doc)
    this.doc=doc;
In your test command, handle over the Document to the Form:
using (ViewListForm thisForm = new ViewListForm(doc))
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 14
Thanks both for your quick responses.
Revitalizer, your instructions were very clear. I did as you said and the drop down list still does not populate. Any ideas?
Below the windows form code:
            this.doc = doc;
                if (!v.IsTemplate)
Below external command code:
desantis15, I tried your suggestion but I don't know what to do with that list. Is it to use it in my foreach loop instead of the FilteredElementCollector? If you could reproduce the whole ViewListForm_Load class it'd be great.
Thanks again.
Message 5 of 14
Revitalizer
since you already fill the list box with strings, you don't need to use the approach using databinding, DisplayMember and ValueMember.
Remove
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 6 of 14
Thanks again for you quick answer Revitalizer. Unfortunately I have removed that line of code and still does fill the box. This is very strange, any other ideas? Many thanks.
Current windows form code:
            this.doc = doc;
                if (!v.IsTemplate)
Message 7 of 14
Revitalizer
change this:
to that:
foreach (Element elem in fec.ToElements())
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 8 of 14
Thanks Revitalizer, but still does not work 😞
Current code:
            this.doc = doc;
                if (!v.IsTemplate)
Message 9 of 14
Revitalizer
are you sure your ViewListForm_Load is called at all?
Are there View3D elements in your document?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 10 of 14
Thank you for your patience.
Sorry for the basic question but how / where do I call the function. The code is the one I posted above.
In regards of the 3DViews in the project I am sure I have a couple of 3D views.
Message 11 of 14
Revitalizer
right-click on ViewListForm_Load, select "Find all references".
Is there only one entry (the method definition itself), or is the method called anywhere?
Or create a breakpoint inside the method, see if it is being hit.
You also could fill your combobox after the InitializeComponent() call, in the constructor.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 12 of 14
That must be the problem. If I click in "Find all references" there is only one entry (image below). How can I solve this? Many thanks again.
Message 13 of 14
Revitalizer
in the form designer view, go to the properties palette, swich from properties to events (the flash symbol), scroll to Behaviour section, go to "Load".
If you click next to Load, there you can select your existing method.
Once connected this way, your method will be invoked when your form has been loaded.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 14 of 14
That was the solution!! Many thanks Revitalizer for your responses and patience. My drop down list below now filled!
