3D polygons boolean operations
c_hanschen
c_hanschen
Is there a way to construct 3D polygons (not in model, just for calculations) and perform boolean operations?
(substract, union)
I'm looking for a way to substract a face from a face, but both faces are not actual faces but result of calculations.
There is no 'New' available for Face.
see attached image for more info.
looking for:
 dim Face1 as List (Of XYZ) From {p1,p2,p3,p4,.......}
 dim Face2 as List (Of XYZ) From {p10,p11,p12,p13,.......}
NewFace = Face1.substract(Face2)
Revit makes these calculations posible for Points (XYZ) and Lines, calculate distance, intersections, etc.
Thanks in Advance,
Chris Hanschen
LKSVDD architecten
The Netherlands
KM_Yotsuha
you can try Clipper~~~
first,you create a local coordinate system where  z of point in this coordinate is 0;
then, use method in clipper.dll to perform boolean operarion,get  result points;
transform the coordinate to globle coordinate~~
c_hanschen
thanks for your comment, I will give this a try!
I thought maybe Revit has it own 'clipper', but i will try this!
Thanks!
Chris
KM_Yotsuha
Plan B:
1、create curveloop by points;
2、create solid by extrusion
3、boolean operation on the solids
4、get face from result solid~~~
I have not tryed this way yet,hope it can work for you~
jeremy_tammik
Performing a 3D Boolean operation to calculate a 2D Boolean result is a huge waste of resources.  If your 2D faces of interest are planar polygons, there are much simpler solutions available:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.2
c_hanschen
@jeremy_tammik , thanks for your reply.
I understand what you are saying, but my planar polygons can be horizontal, vertical or everything in between.
So I thought there would be a simple solution for this, calculation to 2D, substract and calculate back to 3D would also be not so simple.
I think I am going to give clipper a try.
Thanks again!
Chris
jeremy_tammik
Yes, it simplifies things a lot to transform the planar polygon in 3D space into a simple 2D XY coordinate system. I explained how to do so early on in my exploration of the Revit API, 14 years ago:
https://thebuildingcoder.typepad.com/blog/2008/12/polygon-transformation.html
So, you can imagine how fundamental and also simple this task is.
It is vastly simpler than trying to perform a 3D Boolean operation; probably several orders of magnitude less computation effort.
