2020 C# Code Error
2020 C# Code Error
CHtCAD
2020 C# Code Error
CHtCAD
We keep coming up with the attached error when running one of the button commands in a legacy tool we had developed by a third party. The tool generates schedules from an assembly and re-numbers the items in order. The code has worked fine in 2017 up to 2019. We have just moved to 2020 and the attached error on the snip attached keeps coming up when we run the command. There must have been a change to the Revit API in 2020 which has broken it. We have the source code in C# which we can recompile.
Any ideas anyone? Error attached.
RPTHOMAS108
This is likely not a quick fix in terms of changing one member for another because the UI functionality changed in 2019, after 2019 you could use (both AND and OR rule combinations).
Extract from 'What's New' section' 2019 API:
"ParameterFilterElement.SetRules() <Replaced with> ParameterFilterElement.SetElementFilter() The new function sets the ParameterFilterElement to contain an ElementFilter representing the combination of filter rules."
So you need to create an equivalent ElementFilter (to your previous AND filter rule collection).
