Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
2015 to 2016 grid line reference problem
4 REPLIES 4
desdinova
601 Views, 4 Replies
ReferenceArray thirdDimension = new ReferenceArray();
            IList<Reference> myRefs = uidoc.Selection.PickObjects(ObjectType.Element, "Pick");
            foreach(Reference r in myRefs)
                Element element = doc.GetElement(r);
                Grid grid = element as Grid;
                Line gridLine = grid.Curve as Line;
                XYZ direction = gridLine.Direction;
                thirdDimension.Append(gridLine.Reference);
            XYZ firstPoint = uidoc.Selection.PickPoint("Select first point");
            Line firstLine = Line.CreateBound(new XYZ(firstPoint.X + 200, firstPoint.Y, firstPoint.Z), new XYZ(firstPoint.X - 200, firstPoint.Y, firstPoint.Z));
            using (Transaction t = new Transaction(doc, "Add Dimension"))
                t.Start();
                Dimension third = doc.Create.NewDimension(doc.ActiveView, firstLine, thirdDimension);
                t.Commit();
Helo everyone
The code above works revit 2015 but does not work 2016
There is no error when compling
How can i solve this
Thanks in advance...
4 REPLIES 4
boostyourbim
in reply to: desdinova
In 2016 get the grid reference like this:
Reference gridRef = null;
Options opt = new Options();
opt.ComputeReferences = true;
opt.IncludeNonVisibleObjects = true;
opt.View = doc.ActiveView;
foreach (GeometryObject obj in grid.get_Geometry(opt))
if (obj is Line)
Line line = obj as Line;
gridRef = line.Reference;
desdinova
in reply to: boostyourbim
Thank you it worked.
hi, i got the same problem with the dimensioning between grids but your solution doesn't work in my case. the reference of the line is always null.
Scott_Wilson
Removing the view from the geometry options might make it work for you.
Rail Community
