Website is showing up in WRONG Language. It is unreadable.
Steps to reproduce
When I go to the autodesk forums (https://forums.autodesk.com/), everything appears in Portuguese. The emails I receive from autodesk community is also all in Portuguese. I have made sure that both my browser and autodesk profile language has been set to English, but it does not change anything.
Expected results
I expect the autodesk site to appear in the language that I choose. I expect the emails I receive from autodesk to be in the language I choose.
Actual results
The website shows everything in Portuguese. All emails I receive are in Portuguese.
URL where issue occurs
Browser
Chrome
OS
Windows
4 Comments
pendean
Community Legend
This comes up constantly, weekly?, you can search around here if you want. Just change location here, it happens, no one know why because no one is monitoring your webbrowser (all Autodesk webpages have that fix too).
HTH
kevinle2
Status changed to: Bug Identified
Hi @dcaiW26XZ ,
Apologies for the inconvenience. The solution @pendean should fix the issue. However, since this is a recurring issue, we're now researching on why this is happening. Thank you for bringing it up.
dcaiW26XZ
Hi I figured out the issue.  I had to go to my forum preferences, and then changed the language under preference options from "English (US)" to "Use default (English(US))". I am unsure why this was an issue because I have never changed my language before. It just one day starting showing up in Portuguese. Please see my image below for the fix.
pendean
Community Legend
Excellent tip. Thanks for sharing. I'm going to change mine to that as well.
