AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Superseded address?
Superseded address?
Steps to reproduce
Thank you for contacting Autodesk. This email address has been superseded by our updated support process. If you have a problem using your software please consider searching for a known solution on the Autodesk Knowledge Network or in the active Fusion Community.
You may also consider contacting us through the Autodesk Knowledge Network. Click here for a comprehensive list of contact options.
Tip: Sign in to gain full access to your subscription benefits
Expected results
Can I please get to be able to use the app I have no teams on the web to join
Actual results
Not being able to use the cad on your app
URL where issue occurs
Autodesk.com
Browser
Safari
OS
Apple
