My Autodesk username is not appearing correctly
Steps to reproduce
My username should just be "ampster40". However a post I made on this thread this morning shows my username as "ampster402".
I have already reported this thru other "report a website issue" buttons found thru out here but nobody has replied or provided any information that someone is looking into this.
Expected results
My username should only be "ampster40", nothing more.
Actual results
As reported here it is "ampster402" but in other posts I've seen it show "ampster401". There are no characters or numbers after the 0.
URL where issue occurs
forums.autodesk.com
Browser
Chrome
OS
Windows
3 Comments
kevinle2
Status changed to: Investigating
Hi @ampster40 ,
Please go to profile.autodesk.com and have your username changed there. Please let me know if that solves your issue. Thank you.
ampster40
Hi again kevinle2,
Sorry for reporting this in two locations but this is the same "ampster40" from the other msg you responded to.
hth
kevinle2
Status changed to: Bug Identified
We are now investigating internally as this is a consistent problem that has been going on. I will update this ticket as we make progress on this. Thank you for your patience.
