I am not allow to reply
Steps to reproduce
I keep getting an error stating that I have highlighted areas that need to be dealt with, I went through the reply and did not find the highlighted areas.
Expected results
I have posted replies before doing what I just did with success
Actual results
the forum site refused to send the reply stating I had an error that could not be found.
URL where issue occurs
https://forums.autodesk.com/t5/forums/replypage/board-id/706/message-id/1130256/attachments-key/6796...
Browser
Firefox
OS
Windows
2 Comments
pendean
Community Legend
@ktnalive "post flood detected" is the website control that kicks in when you think your post did not go through, but it actually did, and you click that OK button a second or third time.
That appears to be what happened, see below.
kevinle2
Status changed to: Cannot Reproduce
Hi @ktnalive ,
It appears you were able to post as I've checked the thread. As @pendean stated, "post flood detected" is the website control that kicks in when you think your post did not go through when the system just takes a bit of time to get there. As this is an isolated incident I will be closing this.
