Edit my Post please...
Steps to reproduce
hello,
i would like to correct a word in my earlier post, since it is a reference to someone else's work.
i have the word "soso" in the middle of my initial description of the problem in the forum. I would like to change it to a hyperlink to another Autodesk forum response.
Expected results
... differently, i tried @aignatovich (as hyperlink to https://forums.autodesk.com/t5/revit-api-forum/how-to-retrieve-shared-parameter-values/td-p/7434465) method.
Actual results
...differently, i tried soso method.
URL where issue occurs
https://forums.autodesk.com/t5/revit-api-forum/how-to-read-the-value-of-a-family-instance-sharedpara...
Browser
Firefox
OS
Other
6 Comments
alodiac
Status changed to: Accepted
HI @fawzimasri7137 - I updated your reply but can you confirm I linked the right word?
alodiac
alodiac
alodiac
Status changed to: In Progress
fawzimasri7137
I went to the forum, and I did not see any change.
So I am not sure if you actually changed it or just asking to confirm again.
After looking at it, here is my take on it:
I want to replace :
"differently, i tried soso method."
With this:
"differently, i tried @aignatovich
method
<>eter-values/td-p/7434465> ."
So there will be 2 hyperlinks, one for the "Name" of the user and one for
his "method".
I hope this clear.
kevinle2
Status changed to: Fixed/ Completed
