Code block language setting is reset during edit
Steps to reproduce
When I edit code block in post, code language is set to "General"
OS: Windows (can't be selected from drop-down)
Expected results
Code language of code block stay unchanged.
Actual results
Code language of code block is set to General.
URL where issue occurs
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum
Browser
Chrome
OS
Other
6 Comments
kevinle2
Status changed to: Accepted
Hello @Michael.Navara ,
General is the default selection, so when you made a change to the code block, what change happened to that setting? Can you send a screenshot of your issue?
Michael.Navara
Sample iLogic code block
Dim part as partDocument = ThisDoc.Document
1) First time creation - I choose Visual Basic for language
2) Result after first time creation. Keywords "Dim" and "asare highlighted according to Visual Basic
3) Double-click on code block opens editor again for making changes, but the Language is set to General
4) When I forgot to set Language manually, syntax highlighting is lost
kevinle2
@Michael.Navara
Thank you for providing screenshots and steps to reproduce. I was able to replicate and a ticket has been created in our system and our engineering team will look at this soon.
kevinle2
Status changed to: In Progress
Hi @Michael.Navara ,
This bug has been identified and is currently a work in progress. This will be fixed in the next release. Thank you.
Michael.Navara
Thank you for info
kevinle2
Status changed to: Fixed/ Completed
