Every time I go to open Remake it says it needs updating to the newest version. After reading various comments in the forum, I have uninstalled the software and reinstalled to new location, the software still says it needs to be updated upon starting it up, therefore I cannot get the software to open.
Please advise on a solution for this.
Regards
Justin Robbins
Solved by hoh.alex21. Go to Solution.
Hey ! I have the same issue, I have installed / uninstalled for the new version, now I have it but will not start saying
A new version of ReMake is available at:
http://up.autodesk.com/2017/MEM/ReMake_172521_Win64_dlm.sfx.exe
Kindly use this new link which will work.
You may also visit the following link to ensure downloading the latest version.
https://remake.autodesk.com/try-remake
Devang
I have uninstalled and re-installed several times without success - I have done and clean install after clearing TEMP and getting rid of all adsk files and new install off REMAKE continues to ask if I want to download the newest version of autodesk remake. Fails to load when I click no and takes me to same
https://www.autodesk.com/education/free-software/remake when I click Yes.
Can you please confirm the build version of ReMake installed on your system ? It should be version 17.25.2.1.
To know the version number:
1 Open Control Panel
2 Programs & Features
3 Check the version column for Autodesk ReMake listed in the Program name list
If version number is not 17.25.2.1, then uninstall the existing ReMake and download the latest from:
The EDU link you mentioned also has the latest version (17.25.2.1). Please give it a try again and let me know in case of any issues.
Devang
Hi Devang,
This install works, but only 50 photos allowed to create model - used to be 250 - has something changed with educational licence?
Looks good and no issues with this install and all photos now available once I discovered to click on the question mark on the dashboard and go to startup screen and choose enter liscence and product key
