Remake 2017 all users
I have a network license for Remake and every other Autodesk product, however, Remake is the only program that does not retain the license server info across all users. Every time I load Remake as a new user, it asks to activate and then for the network license manager.
I cannot figure out if this information is in the registry or a file somewhere, but I need to configure it.
Also, this is the only program whose deployment creator does not allow me to input the network license manager in for the package so as to avoid this like all other deployment creators allow.
This is Remake 2017 on Windows 10.
I have solved my own issue.
There is a registry entry that appears to be just for Remake, which I do not believe is documented and is the culprit:
HKEY_CURRENT_USER\SOFTWARE\FLEXlm License Manager - Remake needs to be setup with a user and then this entire registry key then needs to be copied to the Default user hive and then, all users can run Remake without being prompted for a license server.
I do not believe this is documented as it is the only 2017 Autodesk app that requires this registry entry.
