so i have published on to project play i was wondering can i place the model and viewer on to my own website?
hi, yes
when you click Publish in ReMake, you land in a Play web intermediate site where you can pick which template you want drag and drop over th emodel), change background, vis style etc and click on the top button: Publish to Gallery.
this will publish the model on the Autodesk ReMake Gallery https://gallery.autodesk.com/remake
once there ( make sure you LOG IN on the gallery - top right) and when you are logged in and you see on the left the model you published, there are 3 buttons on the bottom right in the viewer - the second one is embed : you can use the HTML embed code to insert the view in a iframe on your blog. you can use the hyperlink option to share the view via email etc. let me know if this is clear
see the video i posted HERE: http://forums.autodesk.com/t5/remake-forum/how-to-publish-to-gallery-or-other-place-to-share/td-p/67...
t
Our company has a policy to avoid external links. Would it be possible to host the data files (.OJB?) as well as the viewer (JavaScript?) on our servers, please? We're also concerned Autodesk might pull the plug on this free ReMake Gallery in the future.
Thanks for your understanding.
Best regards,
FGN.
yes, we have been increasingly reviving this requirement and are prepared for it. This is what the Play team did for the Smithsonian implementation and other pilot implementations. We are currently working out the business model of how to offer private hosting. you can connect with me directly to discuss and stay in touch on all things Project Play. tatjana.dzambazova@autodesk.com
tanja
yes, we have been increasingly recieving this requirement and are prepared for it. This is what the Play team did for the Smithsonian implementation https://3d.si.edu/explorer?modelid=55 and other pilot implementations. We are currently working out the business model of how to offer private hosting. you can connect with me directly to discuss and stay in touch on all things Project Play. tatjana.dzambazova@autodesk.com
tanja
