I have a existing point cloud that I want to supplement with a Memento mesh taken from photos. What would you suggest as a good workflow to align the Memento Recap export with my existing Recap info so that they both line up in the same spot?
Solved by vidanom. Go to Solution.
You can by submitting the photos through ReCap360 for this specific case.
The workflow is explained in this webinar.
However, I believe this feature will soon be added in Memento too, where you can add coordinates to the images, or better yet on the model directly.
Cheers,
Mitko
