ReCap SDK Forum
Welcome to Autodesk’s ReCap SDK Forum. Share your knowledge, ask questions, get support and explore popular ReCap SDK topics.
SDK function to delete deleted points is not working
1 REPLY 1
omar_zerhouniWN246
230 Views, 1 Reply
We have noticed that the function deletePointsFromStructuredScan doesn't work with recap files from Recap 2024 and Recap 2025. It returns all points, even the one that are deleted.
We have compiled a minimal app that enable to reproduce the bug.
Also, ReCap SDK 2024 download is missing some files.
Is there changes in the ReCap SDK ? Is there a different function that we should use ?
1 REPLY 1
Hi @omar_zerhouniWN246,
May I know the way how you delete points from the involved ReCap project?
I assume you are using ReCap Pro to delete points. For the involved project, after some points are deleted, and if the project is saved, a dialog will pop up, could you use the first option as illustrated by the blue arrow and then use this project to test:
NOTE: do keep a copy or copies of the ReCap project(s) before deleting points from the project(s). This is a gentle reminder so that you won't lose important data.
Rail Community
