ReCap SDK Forum
Welcome to Autodesk’s ReCap SDK Forum. Share your knowledge, ask questions, get support and explore popular ReCap SDK topics.
RCPointBuffer: write 3D point data as float instead of double
3 REPLIES 3
lamorlette
661 Views, 3 Replies
To create RCS files, I use RCPointBuffer::setPositionAt(unsigned int index, const RCCommonNS::RCVector3d& point), which takes double (double precision floating point real number) data as input parameters.
Can we rather write float (single precision floating point real number) data in the RCS files?
3 REPLIES 3
yan.fu
in reply to: lamorlette
May I ask the reason why you want o write float data as input parameters?
The float data will still be converted into double in Reality Solutions engine. So it won't make difference for RCS file size.
lamorlette
in reply to: yan.fu
I thought it could impact the RCS file size. If not, indeed, there is no point in writing floats in RCPointBuffer.
yan.fu
ReCap engine has done a lot work to reduce the size of .rcs file according to the coordinate value information, so it doesn't make difference if the input if float data or double data type.
Rail Community
