ReCap SDK Forum
Welcome to Autodesk’s ReCap SDK Forum. Share your knowledge, ask questions, get support and explore popular ReCap SDK topics.
Normal calculation and segmentation do not work when loading a scan.
3 REPLIES 3
amuravievQ565R
360 Views, 3 Replies
Calling RCStructuredScan::process() for one scan from the test project from ReCapSDK_v24.0.2 fails. To load an RCS file I use RCScan::loadFile(). If I load the RCP file using RCProject::loadFromFile() and then call process() on scans from the project, it works fine.
Maybe someone knows what the reason is?
Best regards,
Aleksei
Labels (1)
3 REPLIES 3
Hi @amuravievQ565R,
The case you mentioned when it fails is not supported.
Maybe then it makes sense to expand the comment on the method bool Autodesk::RealityComputing::Data::RCStructuredScan::process()?
Now there is the following:
///\brief Process this structured scan to generate derived information such as normal and segment
///\return True if the process is successful. False otherwise.
bool process();
There is nothing to indicate that the result of the method will depend on how the scan was obtained.
Hi @amuravievQ565R,
Thanks a lot for your suggestion! I will let the related team know your feedback.
Rail Community
