Issues Accessing All Points in Structured Scans with ReCap SDK
stephen.sakharov
stephen.sakharov
I've encountered an issue while working with some ReCap projects using the ReCap SDK, and I hope someone can provide guidance to what's happening:
I have scans that are marked as structured.
When I use scan->getNumberOfPoints(), it reports a number that's much larger than what I'd expect from the grid dimensions (i.e., scanRows * scanColumns).
When I iterate over the rows and columns of the structured scan and ensure each point passes being tested with structuredScan->isBadPoint(pixelIndex), I end up with even fewer valid points than expected.
This issue happens whether I load the project with RCProjectUserEdits::None or RCProjectUserEdits::All.
If I use an RCPointIterator, I can access all the points in the scan as reported by scan->getNumberOfPoints().
This is true regardless of whether I set RCPointIteratorSettings::setIsVisiblePointsOnly to true or false for these projects.
I want to access all the points as a structured scan because I need the grid layout (rows and columns).
Can someone help me understand why I am seeing this?
Stephen.
Replies (0)
