Set Default Project Units
Whenever I go to use the measure tool in Recap I have to switch it from metric to feet & inches. If there was a way to set default project units that would be great.
4 Comments
tim.vetter
I want to set Recap's default project units to mm every time I open recap.  Can this be done?
tim.vetter
I just discovered that when I add additional FLS scans to my project Recap CHANGES my mm setting BACK to meters.  I change my setting back to mm and then add more scans and I am back to meters again.  What is going on here?   AAAARRRRGH!!!!
vidanom
Hi All,
The same units can be used and should appear on saved projects.
ReCap will go back to metrics whenever you start a new project.
Mitko
ryeDT6E8
Community Visitor
Why Does it goes back to Metrics when we start a new project? Why can't it stay as what the setting as we set it before? Why do we always have to change the unit every time we start a new project? Why do you put us in such agony!!!
Rail Community
