Creat an Undo Button
Recap is one of the few programs that doesn't have one, it's useful for example when :
delete a wrong scan
clean some important points
put wrong coordinates
and other mistakes
Think about it and keep up the good work, cheers
Miguel Antunes
2 Comments
SolidPoint
to add to the list: useful when combining groups.... nothing worse than combining 2 groups of 50 or so scans, to realise an error, then having to disband or remove scans 1 by 1 and starting both groups almost from scratch!
jburke
Not sure how this has not happened yet!  As SolidPoint mentions Recap will say it has found a good match between two groups, everything looks aligned in the preview... then it decides to "refine" it on its own and without any error or warning, it places the group incorrectly and you have to remove scans one by one and start over.  Typically you'll get a red or yellow error asking you if it's ok to still place the group, but not in some cases.  Have wasted the good part of an entire day on this and it wouldn't be so bad if there were an "UNDO" button.  More and more, I'm realizing Recap is ok for small interior scan projects, but not larger ones with interior and exterior.  Please add an undo button!
