I've just been cleaning up a scan for the past 30 mins or so and whilst the in-built cloud tool 'Cleanup' does an OK'ish job, it sill take a great deal of time and then removes points which should not be removed and leaves many which I need to remove. I the had to use the fence selection and removal tools repeatedly to get close to a fully cleaned model.
The points I want to remove are create by the laser bouncing off of glass and reflective surfaces. My thinking is that because all points created as a reflection are effectively white, would it no be possible to add a cleanup tool which looks for point of no colour? I believe that the only objects which would be this true white would be reflections as even white surfaces are going to have RGB values applied which are close but not fully RCG 255, 255, 255
These white reflection points are all around and inside the building.
This would save an huge amount of time.
