When transitioning between view states, all of the properties of the view (View position, Color Mode, Perspective/Ortho) smoothly animate between the View States. The Limit Box, however, does not animate and jumps to its set position at the end of the View State transition. It would be more elegant if the position and orientation of the Limit Box would smoothly animate while transitioning between View States. When going to or from a View State that does not have a Limit Box set, it should transition from the extent of the bounds.
