I have installed recap and played with it for 15 minutes. I was wondering what's the purpose of this software other than showing pointcloud data? Does it align pointclouds if I have multiple scans? Does it let me draw splines on point cloud and export? Does it export the plane that creates based on 3 points? Or is it just to show point clouds and allowing one to take measurements between points?
Recap is a point cloud visualizer and editor (that basically means you can delete points you don't need).
With the Pro version you can mesh your pointcloud and obtain a 3D object made of textured surfaces.
It may seems somehow limited in it's capabilities and that's because it is considered as part of a workflow. Adding planes, or line, or else… it's usually a task you exploit in other specific software upon an imported pointcloud.
