Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
What is the Recap decimation algorithm?
1 REPLY 1
lamorlette
2321 Views, 1 Reply
When exporting a point cloud from Recap, one can set the decimation grid spacing ranging from 1 mm to 100 mm.
Please, what are the details of the decimation algorithm run by Recap? Does it:
  • take randomly a point (or the first one) in each cube of the decimation grid?
  • create a mean / median point from all points in the cube?
  • take the point that is the closest to the mean / median of all points in the cube?
  • do something else?
Also, is it the same algorithm than the one when importing a file in Recap (in the advanced scan settings, there is a similar decimation parameter, with the notable difference that it can be switched off)?
Tags (1)
1 REPLY 1
yan.fu
in reply to: lamorlette
It is the following case:
  • take the point that is the closest to center of the cube.
Rail Community
