Using ReCap for modelling a building front
I want to model the front of a building so as to produce a 3D model.  I can take photos from left to right.  Just need to model the details on the front.
jayson.sterba
hi @Anonymous,
You can use ReCap Photo for this. Make sure that you are on the latest version (v19.1.1.2)
You will want to take one photo for every 5-7 degrees you rotate around the building.
Additionally, you will want to take photos from at least two different heights following the same guidance as above.
Please let me know if you have any questions.
 Please Accept As Solution if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Jayson Sterba
Customer Programs Manager, Preconstruction
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @jayson.sterba provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
I will give it a try.  The building is located 100 miles from here so it may be a while before I am there.
