Announcements
Update origin by fixed values
justin_chadburn
justin_chadburn
I would like to update the origin of a point cloud by fixed x,y,z values to bring a georeferenced scan much closer to 0,0,0 and allow applications that don't like georeferenced data to use it. The values need to be fixed so the completed design can be "transformed" back to OS coords with accuracy. I have a workflow to get round this at the moment, but it's far from ideal. I should also clarify that the point clouds are often unified so adjusting the registration is not an option.
arron.craig
You should be able to just select "Update Origin"
justin_chadburn
Thanks. Turns out I should have tried the latest version before asking the question. I was still using 2019. Brilliant update - well done Autodesk!
