I want to install recap again because it has been uninstalled by a mistake
Solved by barmanr. Go to Solution.
Hi @mostafasedky65 ,
You can go to your manage.autodesk.com account and sign in with your credentials. There under Products and Services, and under Recap, you should be able to install the product again.
Warmest Regards,
Rishov Barman, Reality Capture
