ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Trying to Publish from Recap (Final goal to export .RCP to LandXML)
1 REPLY 1
thomaskryan03
192 Views, 1 Reply
Ive installed latest Autodesk Desktop Connector and latested recap, have import recap file with points, and now trying to publish it.
Im being asked to select a valid autodesk connected drive location. And ive made new folders etc.
Is this an issue with the desktop connector? The autodesk Drive? or am i missing something?
Cheers.
Tags (1)
1 REPLY 1
zhaoyang_ma
in reply to: thomaskryan03
Hi @thomaskryan03,
May I check with you about the versions of Autodesk ReCap and Autodesk Desktop Connector? Are the following versions correct?
  • Autodesk ReCap 2024.1
  • Autodesk Desktop Connector 16.5.0.2083
In the dialog, I see there are 0 scans which can be selected. This means the project does not contain structured scans. So the project won't be published even if the current error message is resolved.
For a project which does not contain structured scans, the scans can be viewed if it is published to Autodesk Docs. You can refer the help document for more information.
Rail Community
