Moving the mouse over the point Cloud give you the coordinates X, Y and Z; but is there any way to annotate it?, marking the point and get a permanent label like linear dimension does.
J. Samuel Santana F. | LinkedIn
Solved by anil_mistry. Go to Solution.
Hi @samuelsanf,
This is good question. At the moment, you can’t exactly create coordinate label but you can add Note at specific point, hover over note point then click on target to copy coordinate points at that point. Past this point to note, hit ok to save it. Please, let me know if this helps.
If you have any feedback that you would like to submit regarding any enhancement, please click on the “ReCap IdeaStation” link on the ReCap community home page. This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Thank you and have a great day!
Hello from Spain, Samuel
Untill now there is not posible to tag coordinate points in ReCap, at least no ordinary points.
It is possible give coordinates to target points, but this coordinates are not shown anyway in reCap.
But think that ReCap is not a program to annotate or tag like AutoCAD. The better way is insert your pointcloud in AutoCAD and tag or annotate here.
Regards.
