Trying to create rcs file from las file but cannot launch the project even tho it says "indexing scans 100% complete"
Solved by Maksim.Melnikov.BY. Go to Solution.
Hi @renars_pantelejevs ,
This is weird. Has this project been suspended before?
Could you share your las file with us for further investigation? Thank you!
Yan
Hello @renars_pantelejevs
Try to rule out two possible errors:
1. Invalid characters in the name of the LAS file - rename for example to "123.las"
2. The path to the LAS file is too long - move the original file to C: \
Try importing again.
Sorry for late response, but second one solved my problem. Wouldn't thought of it myself.
Thank you!
