Announcements
Stuck at 1% Waiting in queue
Email id is
Maksim.Melnikov.BY
@Anonymous If you use a free education license, there are fixed no. servers running on tasks for all users of education licenses. In this case, your project will queue and will be processed after some time.
A hang of project processing at 40 or 100 percent may be due to several reasons. I had the same problem, I analyzed the reasons for a very long time and talked with technical support. As a result, I wrote an article on preparing the source data for project processing.
You can familiarize yourself with her, maybe she will help you solve your problems (article in Russian). Typically, processing problems are due to errors in the source data!
https://knowledge.autodesk.com/ru/community/article/302621
Maksim Melnikov LinkedIn | Instagram
Autodesk Solutions Expert
Autodesk Certified Instructor
Type a product name
