Stuck at 1% Waiting in queue
Message 1 of 55
I've attempted to create a model using only 39 photo's and it stopped at 1% waiting in queue, I gave it 4 hours and didn't move so had no choice but to cancel. Can it and / or my cloud credits be retrieved please?
Will share project folder just need email address.
Stephen.
Replies (54)
Message 21 of 55
critesh
Hello @Anonymous
Please send me your project name which was stuck in queue.
Ritesh Chandawar
ReCap Pro, ReCap Photo, Dynamo, Fusion 360, Revit
Message 22 of 55
I have tried and eventually stopped several Projects. The one that is currently stuck at 1% is called "snake1".
Message 23 of 55
I am using the Education Licence and having the same problem again!
I found that if I try a non education trial version, my models seem to get processed.
 Wonder if they are prioritising the "trial version" over the education account?
Message 24 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, provide your project name and will have development team look into this.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 25 of 55
i first did a scan ant it completed, it didnt work but it completed.
I tried again using new pictures and it is now stuck at 1% in the queue.
I have ReCap Photo and thois is where it is showing 1%.
Message 26 of 55
Also, my first rendering that did complete, now shows "Visualization Failed, Click here to fix".
I clicked to fix it, but nothing seems to be happening.
Attached is a pic of my screen.
Thanks!
This seems to be an amazing tool if I could just figure out how to properly use it!
Project name:
   GTR Console
Message 27 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! I just want to  let you know that EDU queue is limited in processing since it is offered free. Please, use this queue very conservatively so everyone can process their job. Also, development team recommending to reduce images resolutions to 12MP.
Anil Mistry
Message 28 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 29 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Please, see suggested solution from this post. Let me know if this helps.
Anil Mistry
Message 30 of 55
My model was finished, although the surface is quite rough and un even. I will try to process my job again following your suggestion of a smaller file size per picture.
Thanks for you help and concern.
Mitch
Message 31 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your reply and let me know if you need additional assistance.
Anil Mistry
Message 32 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @ambim,
I’m just following up to see if you were able to gather the information I had previously requested to assist me in troubleshoot your issue.
Anil Mistry
Message 33 of 55
I'm having the same problem (stuck at 1% for 24 hours) on a project called xmas35mm-soft-light-crop with 74 photos. The photos are all under 4mb each.
Is it better to cancel a job and retry it or wait longer? I don't want to cancel and loose my place in the queue. But if I'm not in a queue and it's a glitch, then it sounds like I should cancel.
These photos have space in their file names after I processed them with photoshop to remove the background via cropping. Could cropped photos or spaces in the file name cause the project to get stuck?
ReCap Photo 18.2.0.8 Education License
Thank you for any direction!
Message 34 of 55
Shortly after I posted the project was processed. Pure luck or did my post cause the project to get pushed through?
Message 35 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your reply and I am glad to hear that the issue is now resolved. Please, let me know if you have any other questions or concern.
Anil Mistry
Message 36 of 55
Hi, can you please also help me? I have exactly the same problem. I have updated the pictures and now I am stuck at 1%. What can I do? I am also with an educational license. I am using the last version.
Message 37 of 55
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community ! Your job is still in queue and it will get processed as per its priority.
If you resend the job it may take more time than the one which is already sent.
Please, let me know if this helps.
Anil Mistry
Message 38 of 55
rttgnck
What is the standard time for the queue? Just uploaded 149 photos and looking at 1% queue. Why can't we process this on our desktops? I have already ran processing software and it is not outside of the realm of possibilities. I'm sure there are a number of users that would like at least the option to process on their desktop rather than cloud. Might mitigate the queue.
Message 39 of 55
My project is stuck in waiting in queue at 1% is there anyway that it will process.
Message 40 of 55
critesh
Hello @Anonymous,
If it is stuck at 1%, that doesn't mean it will not process.
It will process, let me know what is the name of your project and License Type?
Ritesh Chandawar
