Stuck at 1% Waiting in queue
Message 1 of 55
I've attempted to create a model using only 39 photo's and it stopped at 1% waiting in queue, I gave it 4 hours and didn't move so had no choice but to cancel. Can it and / or my cloud credits be retrieved please?
Will share project folder just need email address.
Stephen.
Replies (54)
Message 41 of 55
It eventually processed. Thank you.
Message 42 of 55
graham3D4DT
Hi
The main solution here that "EDU license" is low priority is true. BUT it is not the only answer and was NOT the answer in my case. Please highlight this solution to the users.
 After getting nowhere with the EDU solution I looked again at my files. I found that I had copied 2 sets of images from different projects into the same folder and uploaded them all by mistake. Therefore the ReCap software could not resolve the images into 3D. Once I realized and uploaded only a correct batch of images, it work quite quickly. - So I had wasted about 36 hours assuming it was a problem with my EDU license (as suggested here) and not looking more carefully.
So - DOUBLE CHECK YOUR FILES.
Message 43 of 55
Look bys, just download the full license free trial and give er the juice.
She processes right away. And chances are youre only using er one time
anyways. Worked for me itll work for you.
Message 44 of 55
I have an upload that has been stuck on 88% for 24 hours and I cant get any other uploads to move on from 0% either. Is there a solution to this?
Message 45 of 55
Mine was resolved overnight about 12 hours. Maybe try reuploading.
Message 46 of 55
I ma also having the same problem
Message 47 of 55
It should process after some time... i had to wait about a day.
Message 48 of 55
I have the same issue and I use the student license. I have already waiting for a couple of hours but it still stuck at 1% waiting in the queue
Message 49 of 55
barmanr
Hi @Anonymous ,
EDU licenses have a single dedicated queue and hence waiting times can be longer depending on the number of jobs in the queue. Subscribed accounts get priority.
Please refer to this thread: https://forums.autodesk.com/t5/recap-forum/stuck-at-1-waiting-in-queue-in-recap-photo/td-p/10156119
Warmest Regards,
Rishov Barman, Reality Capture
Rishov Barman
Reality Capture
Message 50 of 55
I have the same problem here. I have an educational license, and the pictures are stacked at 1% second day. I have tried different projects and images it happens every time the same, everything get stuck at 1% and nothing happens. What the problem is here? I have a project to complete but I can not do the 3d scan.
Message 51 of 55
bwill828
WOW...This thread started in 2017 and I'm experiencing this still!!
I'm with a business full license $35,000 multi-user subscription, and it's absurd to have to pay more to get Cloud Credits for something like this.  You should at least deduct a credit for every 15 minutes waiting in queue, it's ridiculous!!
Anyway, just had to vent a little, I'm stuck at 1% waiting in queue is there any remedy for this yet?
Message 52 of 55
barmanr
Hi @bwill828,
Possible to provide your project name that is stuck in the queue? I will check at the backend to see if there was some issue. You can PM me.
For subscribed accounts, the wait in the queue should not be too long. EDU accounts on the other hand will take anywhere from a couple of hours to 3 days depending on queue congestion.
Warmest Regards,
Rishov
Rishov Barman
Reality Capture
Message 53 of 55
bwill828
Thanks for the response Rishov, it finished around 2 hours from when I submitted it.  It just took so long to move forward from the 1% that I thought it was frozen so I started some online research and found this thread and posted my situation.  So I've moved on for now and we'll see what happens next time I use this service.
Thanks again!
Message 54 of 55
lottie.may23
Community Visitor
Community Visitor
Off the back of this comment i purchased the full version. It's still stuck what's the reasoning here???????? Is there a way to offline process?
Message 55 of 55
barmanr
Hi @lottie.may23 ,
Could you send me the name of your project? I will take a look if there was any stalling at the backend. How long has it been at "Waiting at queue"?
Sorry, ReCap Photo does not support offline processing.
Warmest Regards,
Rishov
Rishov Barman
Reality Capture
