structure drawing for existing building
hi, i wonder is there any chance to use recap technology to preparing structure drawing for existing building. i mean some thing like column diameter and reinforcement and joint ... . or any similar device. thank you for notice that
critesh
Hello @Anonymous
Let me understand your question.
So you want to scan the building and then you want the ReCap to automatically detect the Column Diameter, Reinforcement Joint?
Is this what you want?
Ritesh Chandawar
ReCap Pro, ReCap Photo, Dynamo, Fusion 360, Revit
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I’m just following up to see if you were able to gather the information @critesh had previously requested to assist him in troubleshoot your issue.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
hi Critesh
my problem is i have old building without structure drawing and i want to know is there any chance for me to scan structure and MEP and reinforcement without Destructive test
I'm in the same boat...final project due in 5 days, all setup and working...the 'low quality' mode was 100 images anyway so in theory I should at least be able to use that mode...but after spending half an hour uploading with my terrible internet connection it just sits at 1% forever.  Hopefully it will at least go through before the due date so I can at least show an example.
If Autodesk is determined to make this a cloud-only service, they could at least make it a cloud service that doesn't require an install bigger than some complete CAD packages.
Autodesk: You spent (I assume) a fortune developing this software.  Then you spent resources getting me (and others) to use it.  I assume the goal was to make us appreciate the software so we buy it?  If so, this whole cloud thing is a total fail because it's forcing me to find a competitor.
