ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
ReCap Forum
Post 1 of 4
Single File of Recap
45 Views, 3 Replies
04-10-2017 10:57 PM
How can we  transfer ReCap data to other computer, as we need to copy complete project folder which is in huge size. Can a single file be created with graphical details and without loosing any data ??
Post 2 of 4
Re: Single File of Recap
04-11-2017 08:01 AM in reply to: rajparakh1986
You will have to copy both the RCP and Support Folder if you are copying the project to another computer.
There are other techniques to reduce the project size - If you have a lot of deletes, you could do SaveAs + Remove Points. This will reduce the project size.
Other option is to do a export to Unified RCS with higher 'refine grid' setting. This will will create a single RCS file and probably reduce the file size a bit. You could copy the unified RCS over to the other computer and import it into a new project. But this will lose any mirror balls and realviews.
Ashwini
Post 3 of 4
04-11-2017 08:35 AM in reply to: rajparakh1986
If you are going to end up just throwing it in navis anyway, you can publish the rcp from navis and have "embed recap and texture data" checked
Highlighted
Post 4 of 4
04-12-2017 12:57 PM in reply to: rajparakh1986
I recommend 7-zip for this - http://www.7-zip.org/.
  1. CTRL+Click on RCP and Support folder.
  2. Right click -> 7-zip -> Add to Archive
Creates a single compressed file for much faster transfer to/from a server or external drive.  You'll need to unzip on the other machine, obviously.
-Ryan
