Is it possible to change the "saved file path"? My saved file path is currently my c drive on my desktop. i have taken several rcp files and aligned them how i needed them in autocad and made a drawing containing the cloud file in it . But if i copy it to a portable hard drive and open it on my laptop the clouds are not there, even though i coppied the entire folder.
Solved by ryan.frenz. Go to Solution.
This is a known issue which will be fixed in the next release. ReCap is able to update the paths to the new location, but AutoCAD is not. The work-around is to open the project once in ReCap on the target machine. You will be prompted to 'reattach' the scan files. Once you reattach one it should find the rest. Save the project again, and now ACAD should be able to load it properly.
Hope this helps.
Ryan
