So I have an 18 scan room that when completed, I want it to align to a specific set of points in an AutoCAD file... so the final pointcloud rotates and aligns to those points.
As a test, I started with only 2 of the 18 scans to try to understand using survey points. I can see during the registration process of comparing two scans that the left window you can click a point and create a survey point by clicking the little arrow under the colored circle. I've created (2) survey points in that scan window naming them CP1 and CP2 and within each of those points I've entered the X,Y,Z values to the corresponding points in AutoCAD (after converting the ft-inches units in CAD to meters for Recap). After creating the two survey points, I clicked the 3 green,blue,red points in each scan and it did it's thing and aligned the two scans. However, after it is done and I click to index the scans... its like it completely ignored the survey points and never aligned the final pointcloud to those survey points.
What am I missing here with regards to survey points? How may survey points do you need to be using? Should I have survey points in more than 1 of the scans? How do I accomplish lining my pointcloud up to my AutoCAD file? Do I need to export the pointcloud to a certain format to get the survey points to kick in?
Also, I noticed that instead of naming the survey point I could import a txt file list. What is the format for that and should I use that over manually creating them? How does importing survey points work?
Thanks for any help.
